Just looking for suggestions and info on what you guys are running for a clutch set up as well as a transmission. I have an 86 GT that I will be running in Stock Eliminator so I am limited to the stock type diafraghm clutch and pressure plate. I also must use a T5 stock type transmission. The engine is a blueprinted 86 HO 5.0, venolia .040 pistons, zero deck short block, stock rods, stock crank, stock e6 heads unported, custom comp hydraulic roller with the factory lift specs but considerably more duration and lsa. I would like to launch the car around 5k and I am not worried about street manners... although I do take the occasional cruise to a show and what not. After looking around on the corral and some other sites i have come up with a short list of what I would consider running... here it is
Clutch
1. Centerforce dual friction
2. zoom race clutch kit
3. Ford King Cobra
Trans
1. Face plated T5 from liberty gears
2. G Force t5 from Hanlon Transmissions
3. TKO 600, also faceplated from liberty
So thats it... any suggestions comments would be great. Bear in mind this will be for racing 90% of the time so street manners is not that much of a concern... also HP and tourque numbers are in the high 290's to low 300's
Thanks Guys!
are you running nhra-ihra stock, or is this a local stock eliminator class, because in nhra-ihra you can run any clutch and clutch assisted tranny
For an IHRA/NHRA stocker with a stick, you really need to at least talk to Rob Youngblood at Advanced Clutches.
www(dot)advancedclutches(dot)com
So many class stick racers have wished they would have coughed up the dollars for one of these clutches rather than waste their money on off the shelf stuff that was not only slower, but broke parts.
This stuff is pricey, but it is the best.
thats an easy answer, mcleod, or advanced and a jerico or gf5R trans
Dont get me wrong... those are both great trannies but I really dont see the need to shell out almost 6k on a trans like one of those for a car that is only going to make around 300 wheel horsepower. Further more (and correct me if Im wrong here) but dont you need to retain the stock type transmission and clutch in order to run in Stock eliminator? If someone knows where the rule book is that spells these things out please point me in the right direction.
