How do you guys mount your race belts? I just got a car with 4 point RJS belts but the guy only attached the lap belts to the floor. The shoulder harnesses are just resting over the seats. What's a good way to mount them? Pics please. The car also has a 6 pt. cage. Thanks guys!!
Are the belts bolt in or wrap-around style?
I use a G-Force 5-speed that bolts to welded tabs on the cross bar (NHRA Legal).
I'm not really sure. The shoulder straps go 2 into one for the mounting location. I'll get some pics tonight.
You could either weld a tab to mount the "rollbar mount" style to, or just buy the "wraparound" style that go around the bar. If you have the belts that go 2 into one with a small triangle tab with a hole in it then that needs to be bolted to the tab on the bar if you have one.
