Hi,
I'm looking at using an SCT tuner to disable PATS on a Cobra ECU. This way, I can use the Cobra ECU and Cobra harness on a Lincoln 4.6 DOHC motor. Does the SCT need to be connected all the time? Or do I use it to re-program the ECU, then disconnect it and the ECU will hold the changes?
Thanks,
-Neil.
Gotcha. This is going in a Fox coupe, so no lights around. I won't be using any Ford instrumentation, etc.
Cheers,
-Neil.
