1 - 12 of 12 Posts
Should the feed line to the fuel solenoid be -4AN or -6AN braided line? I think the kit comes with 3/8" rubber hose to supply it if you dont use braided lines but Im not for sure. The Summit description is vague. Thanks
are you refering to the fuel line i hope if it was rubber if so i wouldn't go smaller than a 6.
It is -6AN. I just wasnt for sure if the barb fittings and rubber hose were 3/. Thanks
Use no less than 3/8"=#6 for fuel line and #4 for nitrous even if your not spraying a 250 shot run #4 if you ever go up you wont need to buy new nitrous lines .
Ok thanks. Can anyone point me in the direction of a kit comparison? When I search it I get mainly "for sale" threads and I know it has been asked "which plate kit" before and I dont want to clutter up the board. Im leaning toward an Edelbrock kit, they seem well made. Any tips or opinions? Thanks again
Carb or injected and what size shot are you wanting to use .
im goin with a zex kit when my motor is all done. i like there design of the nitrous spraying all around the perimeter of the plate instead of the normal tubes goin across the plate. less likely for fuel or nitrous to puddle up in the intake with the design.
Carb. 175-200 shot
Here is the kit reference only you can buy a used system on here or ebay for about 2/3 the cost I have included other parts you should get I know a lot of stuff but you need to do it right or you may suffer in performance / not able to run at the track or a motor failure . There is more to it than just buying a kit they never tell you that .
This is the same setup I have just make sure you run a safe tune . As the saying goes run you run rich all the time but you can only run lean once .
http://www.summitracing.com/parts/NOS-02001NOS/
http://www.summitracing.com/parts/NOS-15750NOS/
http://www.summitracing.com/parts/NOS-16160NOS/
http://www.summitracing.com/parts/NOS-14164NOS/
http://www.summitracing.com/parts/NOS-14140NOS/
http://www.summitracing.com/parts/AED-6082/
http://www.summitracing.com/parts/NOS-16032NOS/
http://www.summitracing.com/parts/MSD-8970/
Discussion Starter #12
Thanks for taking the time to post all of those links. My list from summit is pretty long: kit, braided lines, fittings, tee, FP gauge and cup, nitrous pressure gauge, etc.
1 - 12 of 12 Posts
