I am going to be running 10 to 14 lbs of boost on a stock bottom end 95 GT. What size of fuel injectors and and what brand of maf sensor would you guys recommend? Oh its going to be a single T-70 setup. Also do you you recommend running an FMU? I was told that I wouldnt need to. I am new to the turbo game and could use all the help I could get. Thanks.
42 is plenty for most basic 302combo's without an fmu. i like my old pro-m velocity tube and have had goodluck with the pmas protube. sct meter will require a tune with a chip or...
If you have to buy injectors might as well get 60's. No FMU, get a tune, and a good fuel system. I use a MAF from a 03' Mach 1. It has the same I.D. as my intake pipe.
Dont forget about the rest the drivetrain too. Turbo's make big torque.
