I just ordered the S-trim kit with aftercooler (4FK218-050SQ 4.6 COBRA H.O. W/COOLER 96-98):
A couple of questions:
Does this kit necessitate relocation of the battery, and if so, does the kit come with all the parts for that, or will I need to purchase seperately?
What fluid is best to use for the cooler? I would think water with some Water Weter and a small amount of coolant for corrosion protection. If it is a combination of these, what kind of ratio is best?
Thanks in advance guys!
You need to buy a battery relocation kit. Vortech sells one, but you can probably find one cheaper at Summit if you're not to worried about looks.
I would use water with 25% coolant. And it wouldn't hurt to add some cheap electric fans (found at an electronics parts store) to the cooler fins.
