I just bought all new drilled and slotted rotors, pads, and stainless steel brake lines to replace this weekend. Is there anything special I need to know when doing a brake job? I've replaced pads and rotors in the past but never rotors on my Cobra. Is there a trick to getting the old rotors off or do they come off fairly easily? Do I need a special tool for the rear calipers and where can I get one? Are the brake line difficult to replace? I want to buy a one man brake bleeding kit so I can do this myself. Is there a certain order I should do the brakes in? Any advice is greatly appreciated.
Pete
Th job is pretty simple. I did a Cobra upgrade with SS lines not too long ago, here's what I learned.
The rotors were not that hard to get off. I aksed around like you and was told that if they are being pains, take a mallet to them. Your not using them anymore. I started with a regular size hammer and hit around the center part of the rotor and they came right off.
The lines are simple, had to dremel a larger hold in the stock bracket to get my MM SS lines to fit.
You will need a special tool for the rears. You can get it at your local Autozone or Pep Boys. Some people have said you need to modify the tool a little but I guess that depends on brand of the tool. It can also be done with good needle nose pliers, but is not really recommended. I have not done the rears yet personally so I'm just telling you what I have read.
The bleeding its self is simple. Your gunan need someone to help if you don't have speed bleeders or a one man kit. I would get one of the kits, definatly makes it alot easier. Start with the caliper that is farthest away from the Master Cylinder.
Bleed in this order:Right rear, Left rear, Right Front, Left front.
Bleed until all air bubbles are out. There is a good write up on here that I used when I did mine.
Hope that helps
Eric
Where did you find the write up and where did you get the crush fittings?
You mean crush washers? Mine came with the new Banjo bolt with the SS lines.
Make sure you have that banjo bolt for the lines. I bought some from MU, and my car was down for a week because of it. For the washers you can probably try your local NAPA or Autozone.
http://www.corral.net/tech/maintenance/brakebleed.html
Eric
Does anyone know the exact name for the tool I need for the rear caliper? I don't want to go to Autozone and not know what I'm looking for. hehe I need to take another look at my ss lines to make sure they have the crush washers.
