What long tube headers did you use? I have a notch with a Racecraft K member in it and I want to run long tube headers, but I am unsure which ones will fit? Also, I would rather not buy $1000 headers as I plan on installing a turbo kit at a later date.
Did you use motor mounts with adjustability to help the headers to fit? I have a TH400 with an AJE adjustable crossmember that may help figment as well.
Thanks in advance.
In the beginning of time :) most guys used 351w headers and cut the flange off and welded LS1 flanges on them. Fits perfect. I had 4L60e which is a big tranny like the turbo 400.
I used a AJE kmember and dynatech headers on my first build. On my 6.0L I modified a on3 ford kit my 3rd build i built my own hotside and used flipped truck manifolds
how much are the dyno tech headers? Does summit carry them
I bought the Kooks stainless and a lot better header then what I used before. I will be selling one of the other sets that I used for over 7 years
