1 - 20 of 21 Posts
Has anyone used pvc piping for a temporary front mount set up? Im doing this to my 1984 mustang svo
Sent from my DROID RAZR using AutoGuide.Com Free App
Even though I lack a mullet or live in anything near a trailer i used the PVC. Only long enough to get me down the road 200 sumodd miles.
Yea took a few but I'm not allowed to post pictures?
I think its cause you have to get your post count up
Yes its holding up pretty well lol. I never thought it would work
I gotta see how this looks...can you pm pics? I will post them for you
I would but there on my phone, And when I go to send you a message there's no option to attach pictures?
Jersey True Street Guy
Is PVC cement cheaper then copper RTV?
Don't know if it is cheaper but it is easier to install with the glue i am thinking. I think your sealing would be fine with a low boost testing
Discussion Starter #13
I used PVC cement and its holding together at 12 psi. As for the prices its about 4 dollars a container for glue. I also used PVC cleaner for a better connection and that ran another 6
The cleaner breaks the bank.
Lol 12 psi awesome
Discussion Starter #17
Ha thanks guys. I hope it all lasts till this weekend. Then I get the real inter cooler piping :)
I have a B&G cold side for sale if it would help.
FYI, 3" Schedule 40 PVC is rated for up to 158psi working pressure with a burst pressure of 840psi. If you went with schedule 80 (the gray stuff) it will work at even higher pressures. Schedule 40 can handle temperatures up to 140*F although the pressure it can handle becomes de-rated at that temperature by 0.2. Even still, it will handle 32psi at 140* F.
With that said, most turbo setups will not hurt schedule 40 or 80 PVC pipe. It may look like #### but it will work very well.
Again, it will look like ####.
1 - 20 of 21 Posts
