Just wondering what everyone prefers to use with methanol injection. At what power or boost level is a good idea to upgrade to progressive? I plan on 18psi and around 600whp. What nozzle size should I go with here on a v6 motor?
progressive for earlier turn on then gradual spray would make easier tuning i would think. i run a progressive and turn on is like 3psi and have a 15gph nozzle.
If you run a turbo or centri then a progressive system is the way using a map sensor matched to the boost run. On an application using an inexpensive kit with a small nozzle .. A pressure switch can be used. Although most by the time they get wiring an inexpensive kit, it was the same trouble as wiring a progressive kit.
