Hi guys I have a 1987 foxbody with a bottom stock 302. I am running GT40 3 bar heads with the GT40 tubular Intake. I really like the look of the Proform Ford Racing Valve covers summit racing part number is 302-135, but I am afraid that they will not work with my setup. Is anyone currently running these, Im curious as to what all would I have to change or fabricate to run these successfully. I am running an Anderson N41 cam and will upgrade to roller rockers in the future so these cover will eventually become useful. Thank you for your time.
You my have clearance problems with the TB. I ran a set up that was very close to your's ,but I ran a set of Ford Racing covers. These was a very tight fit between the VB and Value covers. You will need a spacer between the upper and lower intake. I'm not sure how much of a spacer and if you can buy one that is thick enough.You also may have other fitment problems. Find out how much higher the Proform's are that what you are running. Roger
