im in the middle of installing an ATI P1X and i have an open race valve i want to install. im a little confused where to put it. does it go in the pipe (#1 in the diagram) right after the headunit towards the intercooler? if so, do i put the flange where the surge hose (P in the diagram) is currently?
You can mount it pretty much anywhere after the head unit, but before the MAF. The area where the surge pipe is currently connected in the picture is a pretty common place.
The picture indicates you might be using a draw-thru MAF. If so, you are blowing off metered air & it will never work properly, except when the BOV is closed under WOT or near-WOT.
