I can't recall if you need to modify the head unit bracket to fit the 351W, but I do know that it places the head unit far enough to the drivers side that you'll need to notch out the fender apron in order for it to fit.
No modification to the head unit bracket required unless you don't have the right bracket. Vortec brackets are the ones that need modifying to fit 351's. Procharger makes the a/c and p/s bracket as well. I had a set, but sold them on here. You may get lucky and find some used.
