I have the foxbody 8 rib renegade setup. Bought a 12 rib crank pulley and a couple matching 12 rib head unit pulleys. The offset is entirely different. I assumed(very wrong) that I could simply swap pulleys from 8 to 12 and it would work. There's no way with what I have this will work. Do I need a different head unit bracket? Or remove spacers out of the mount bracket? Then my alt/water pump wouldn't line up. Please someone point me in the right direction.
Discussion Starter #2
Tried uploading pics but won't work for whatever reason. My 8 rib pulleys stick out 1 3/8 further than the 12 rib. Could extra a pic to anyone with info. Mine is 217 218 2156 thanks
Apparently I bought the 12 rib setup that fits the cog bracket not the 12 rib that fits the renegade bracket with spring tensioner. Live and learn, luckily the guy I bought them from is going to give my money back. Good guy, didn't have to since it was my mistake. Got pic to load, so someone can see the difference and not make the same mistake
