1 - 10 of 10 Posts
This is in my bros 89 hatch. mods are ported e7heads,performer intake,shorty headers and o/r H,e cam,65 tb,255hp fp,24 lb injectors,prom75,kirban fp reg,aod w/2800 stall,4.10 gears. Has the Nos 100 shot dry kit on it and purge. when ever you spray it starts missing. timing is backed down from 15-10 and fuel is at 80 while spraying. has autolight 24 plugs gapped at .035 and stock igniton. I think it is blowing the spark out. I also worry about the locaton of the solonids fron the headers. they are about 2 inches away from them on the strut tower. Know of a better place for them? jetts are 53 fuel 47 nos.
better step up to a msd ignition and coil.
you are running rich , the dry shot is set up for 19 lb injectors, you have 24 s the vacuum tee jet has to change .
you should have closer to 65 psi with the 100 shot , not 80 way to high. check your plugs after a pass and see how rich you are running.
i mounted my sons 88 on the top throttle body bolts, he has a 4" hood.
i noticed you are running a aod . i would buy the msd digital 6.
it will work great with the aod. put your timing up to 16-18 degrees, and set the retard back to 10-12 degrees for spray.
so you launch stong on motor and when the micro switch engages the digital 6 will retard the timing for spray.
cause now you are launching at 11 degrees on motor for n20 , so you ain't launching at full power.
i agree on the dig 6. i have one on the race car. he just started college and is broke. his aod is having problems shifting into 2nd on the spray also.
has pi 2800 nonlockup, hardened input shaft, transgo shift kit, upgraded od servo. we leave it in drive and shifts fine n/a
my sons 88 hatch, has a 3500 stall , 1 pc hardened shaft, p/a vavle body, its full manual with trans brake and electric overdrive, and a new front pump. we spray a 250 wet with no problems.
1 - 10 of 10 Posts
