My wife drove the car yesterday and ran the seat all the way forward. Now the seat will not go back! The power lumber also will not work. I looked in the owner manual looking for a fuse but found none! Where do I start? There is a HIGH current fuse for the lumber, does that supply the seat up/down back/forward control as well?
I've got a similar problem. The power works, but won't move the seat forward.... only back. Up and down is ok in mine.
I've had a similar problem to yours in the past. It's because before my wife drove the car I had the seat out to install the seat extenders, and I didn't fully attach the connectors under the seat when I put it back in. When she powered the seat forward it pulled the connectors apart leaving the seat powerless.
I just reached under the seat and connected the wires. I suppose something similar could have happened in your case.
The fuse for power seat is Right in front of the Drivers side strut tower under the little black cover.
It's one of the smaller fuses, like a 15 amp or so. The seat fuses will pop if the button is held down for any extensive amount of time. Maybe you can try a higher amp fuse like I did.
Good Luck
If I move my seat all the way forward, it pulls the connectors apart. I also had a problem with the lumbar in the seat. It turned out to be a leak in it.
