i might buy a fox bdy as a track car, problem is its four lug. im new to foxes. will the four lug hack it at the track?? multiple runs with 400-500rwhp?
Stock axles no, but if you go with a set of Strange or Moser 31 and up spline axles you should be ok...You would need to change the carrier as well or since it will be a track only car go with a spool. You can but a kit from Strange - http://www.jegs.com/i/Strange Engineering/873/P3108-4/10002/-1
You would just need to add the spool:
http://www.jegs.com/i/Moser/718/5S8831/10002/-1
You probably can find them cheaper but this is just to show you.
I am running Strange 4 lug axles but will be selling them soon. I want to go to a set of Magnum 2.0's on the rear but they only make them in 5 lug.
