For those of that have done this or had this done, can you post some pics, please
tonight i just removed the upper and lower intake and I will be doing some P&P tomorrow. On your intakes was it P&P all the way up inside the runners? Or was it just where you could see it and then some? Does your intake feel completely smooth or is it a little ruff? Should polish the top of the lower intake? And those that have N/A Cobras, what were your dyno #'s before and after? I don't expect alot of hp/tq because its N/A but just wanted to ask.
One other thing I have a single blade t/b coming and I need to grind down the intake bridge. Is there a "correct" way to do this, or can you just grind away and smooth it out until the t/b opens? What about grind stones, any suggestions?
Thanks Again.
Discussion Starter #2
:confused:
