Im doing a carb 6.0 swap into my fox coupe, I have been searching and searching.....I have heard that a fourth gen radiator will work in the swap, so I ordered a 99 camaro radiator, but I didn't see where the steam vent hose connected to it, so I sent it back. I have also a thick fox aluminum radiator, and was thinking about putting a "T" in the coolant over flow fitting in the radiator, but do you think its a good idea because of constant pressure?? Also tried to use a 98 Gt radiator. What exact year has the stream vent on the radiator??
I have the vent line going to the water pump.....alot of people will drill and tap a hole......
I use the Allstar alum. radiator for sbc in a fox body.....there $160 plus tax from the speed shop down the street....Jegs should have them.......think there 19x31 ......and i use the UPR top cover plate...
