I don’t think your email going to find a lot of people hating on Mahle rings, they make a good product. Pretty much any name brand ring will work well if used for the proper application with good end gaps.
We’ve had good luck even with the lower end brand enginetech for more oem type applications.
Sealed power, Mahle, wiseco, all make good rings.
Vendor
4.030” with the speed pro H132cp pistons. Looking at the PC 315 0036 .035 or Mahle 4035 ms.
mahle and perfect circle is same company. At one time the mahle branded ring didn't come with a Napier second design. It does now on all the new mahle 1mm rings, so.its possible it does for these larger rings. If it does, buy the cheaper set since they should be the same in a different box
