wanted to ask,whats a good ball park figure on ring gap for a pump gas turbo motor?
302 with trw pistons and Mahle rings..running intercooled with a small turbo..maybe 15lbs max..thanks in advance
Well, you gotta know more before talking. Bore diameter, piston to bore clearance, compression ratio, expected maximum rpm, ring material, ring width, ring coating, if any.
Otherwise, go two-thousandths of an inch per inch of cylinder bore diameter.
