ok i was setting my pinion angle last night , on the rearend (drive shaft mounting point) angle finder shows 1 deg on the left side of the 90deg mark (using 90deg as my zero) .. and the crank shows 4 deg on the left side on 90deg on the angle finder .. now do i have -3 deg pinion angle or +5 deg of pinion angle ?
Is the pinion pointing up or down at 1* from horizontal?
Is the DS pointing up or down at 4* from horizontal?
ks
ks
pinion is pointing up , drive shaft is pointing down
Doesn't matter.. There is a 3* difference between the driveshaft and the pinion and that angle is all you're looking for.
ks
