I will be removing the obvious motor/trans/harness but would like some input/suggestions on what other items are essential when doing the swap into a 79 Fox. I'm sure there are some odd ball things that I wont be considering at the time and will regret not taking them when the body is long gone down the road....
I did pretty much the same thing your doing the only thing I kept off the donor car were only the motor and trans with all the front brackets on the engine and I used the stock camaro radiator,coolant hoses,trans lines into an aftermarket trans cooler, and mass air meter with the iat sensor in the intake tube you might want to keep the o2 sensors also if your doing your own harness in my harness I needed the lt1 o2 sensors so every thing else went with the roller when it sold.
I used a psiconversion.com harness and computer for my swap so I never removed 1 piece of wire from the donor car. By the way I'm running a 4l60e trans also
