Paxton Novi 1220SL Noise (video)
Video Link: https://vimeo.com/319247918
After 5 years and about 10k miles (weekend cruiser) I have noticed that my blower has developed a "whine" to it that to me is very similar to what a bad power steering pump sounds like when you turn the steering wheel. The unit has had 2 fluid changes since new and the level isn't down. I removed the intake tubing and the drive belt and there is no play in the shaft and when I spin the blower by hand I hear no grinding and it doesn't require any more effort than it used to. I have been spinning it to the max by running an 8" crank with a 3.15 blower pulley, at 6k rpms this equals 54857 rpms on the impeller. However, this rpm is rare and even with aggressive driving I am shifting at around 5500-5800. I believe max rpm recommendation is 52k from manufacturer.
Anyone with experience on the self lubricated V3 Vortech or the Paxton Novi 1220 come across anything like this and was a rebuild in order or does the blower increase in noise as the miles wear the units?
how does the impeller look?
spinning it by hand is not going to replicate the side load as with the belt on
i dont now how they should sound, but all the belt driven hair driers i have heard, whine a lot
Impeller looked fine and no sign on casing that any contact has/is occurring.
I will run it and monitor for any changes with the noise.
Any worse and I'll have to send it off for rebuild.
From my Vortech days I was told by a very good source that you could over spin a Vortech by 10,000 rpms before you had to worry. After that you had to be checking that the impeller didn't hit the volute. Also had to be run a large BOV. I over spun my V2 by 10,000rpm and never had a problem.
