Someone correct me if I am wrong, but I don't believe the Novi 1000 is a big enough blower for an intercooler. Also it should not need one unless you are over spinning it.
I'm currently running 7psi. Can I run more?
I have heard of people running them at 10 psi and over, but I think over 10 psi and the Novi 1000 gets out of it's efficient range.
I have a Novi 1000 myself that I will be installing this spring. I will be starting out around 5-6 psi and them maybe go up to 7-8 psi. More than 10 psi and I think you would be better off with at least a S trim.
Maybe try it at 10 psi and see how it does?
