I have the following car for sale that I want to part out:
00/03 Cobra Clone Fully Built Street/Track Monster Kenne Bell - SVTPerformance
Here is a list of items I have for sale, PLEASE EMAIL ME ONLY IF INTERESTED OR CALL. NO POSTS ON HERE AND NO PM's!!!!!! [email protected] or 678-362-5685
I would like to sell this car in large chunks if I can, a complete suspension package, a complete IRS, a complete engine, a complete Kenne Bell Kit, ect.
Please expect to pay between 50-75% of the new cost of the part.
Parts List:
1999 Ford Mustang GT
Modifications
Engine:
.020 Overbore Built Engine
Diamond 11cc Dish Pistons
Manley Rods
Stock GT Crankshaft
Ford Racing SVO Heads w/ 5 Angle Valve Job
Canton High Capcity Oil Pan
ARP Head and Main Studs
Accufab Large Bore Single Blade Throttle Body
Comp Cams Camshafts
Comp Cams Beehive Springs
High Flow Oil Pump with Billet Oil Gears
Kenne Bell Flat Machiened Harmonic Balancer
Lightning 90mm MAF
Fluidyne Radiator
Castrol TWS 10w60 Motor Oil
New Battery
New Factory Replacement Starter
New Timing Chain Guides, Flapper Arms, Tensioners
New Alternator
Canton Oil Cooler with Custom Stainless Braided Oil Lines
Canton Remote Oil Filter Kit
New Power Steering Pump
New Oil Pressure Switch
SCT Chip
New Water Pump
Cobra Increased Airflow A/C Condensor
New A/C Accumulator/Drier
Billet Timing Gear
New Coolant Hoses
New Coolant Tank
JLT High Boost Cold Air Intake
Ignition System:
MSD Coils
MSD Spark Plug Wires
NGK BR7FE Plugs
Power Adder:
Kenne Bell 2.6L Twin Screw Supercharger 15 PSI
Canton Aluminum Heat Exchanger Tank
PI to NPI Aluminum Adapter Plates
Upgraded Aluminum Heat Exchanger 26"x7"x3.5"
Fuel System:
Veyron High flow in tank pump
60lb/hr Fuel Injectors
Areomotive Fuel Pressure Regulator
MMR Billet Fuel Rails for KB Supercharger
Upgraded -8 Fuel Feed Line, Aeromotice Fuel Filter, Pressure Gauge and Fittings
Exhaust:
BBK Long Tube Headers
VRS X-Pipe (no cats)
Magnaflow Stainless Steel Cat-Back Exhaust
New Bosch O2 Sensors
Suspension:
Maximum Motorsports Strut Tower Brace
Maximum Motorsports K-Member with K-Member Brace
Maximum Motorsports Non-Offset A-Arms with Derlin Bushings
Maximum Motorsports Race MM3 Struts
Maximum Motorsports Race MM3 Shocks
Maximum Motorsports Front Swaybar End Links
Maximum Motorsports Front Swaybar Bushings
Maximum Motorsports Steering Shaft
Maximum Motorsports Front Coil Over Kit with 500lb Hyperco Springs
Maximum Motorsports Rear Coil Over Kit with 750lb Hyperco Springs
Maximum Motorsports Bumpsteer Kit
Maximum Motorsports Cross Axis Kit
Maximum Motorsports Subframe Bushings
Maximum Motorsports Aluminum Adjustable Differential Mount
Maximum Motorsports Rear Tire Rod and Bumpsteer Kit
Maximum Motorsports Rear Swaybar Endlink Kit
Maximum Motorsports Rear Derlin Control Arm Bushings
Maximum Motorsports Caster Camber Plates
Maximum Motorsports Solid Rack Bushings
Complete IRS from 2003 Cobra
New Power Steering Rack
Eibach Rear Swaybar
Maximum Motorsports Subframe Connectors Full Length
Maximum Motorsports Bumpsteer Gauge
18x9 and 18x10 Gloss Black Saleen Replica Wheels
Nitto Invo 275/35/18 and 295/30/18 Tires
18x9 and 18x10 Gloss Black Forgestar CF5 Wheels
Nitto NT01 275/35/18 and 315/30/18 Tires
Brakes:
Stoptech Big Brake Kit (Front) with 14" (2) Piece Rotors
Stainless Steel Braided Brake lines
Front Pagid Yellow Race Brake Pads
New Hydroboost Unit
New Stock Cobra Rear Calipers and Caliper Brackets
Motul Brake Fluid
Hawk Rear HP Plus Brake Pads
Hurst Line Lock Kit
Driveline:
Stock 2003 Cobra Tremec 6-Speed Transmission
Speed Cal Speedometer Calibrator
SPEC Stage Two Kevlar Clutch
FRPP Aluminum Driveshaft
Metco Driveshaft Safety Loop
Steeda Aluminum Clutch Quadrant
Steeda Firewall Clutch Cable Adjuster
3.73 FRPP Ring and Pinion Gears
Torsion Differential
DSS Level 2 Upgraded Half Shafts with Road Race Prep, Freshly Rebuilt
Steeda Tri-Ax Shifter
Reverse Lockout VSS/OSS Control Box
Steeda Adjustable Clutch Cable
Interior:
Classic Soft Trim FR500 Seats
FR500 Steering Wheel
Cobra Gauge Cluster
35th Anniversary Shifter Knob
UPR Billet Items
Kenwood Garmin Navigation Head Unit
Polk Audio Speakers
Coustic 12 Inch Subwoofer
Alpine Amplifiers
Saleen Aluminum Pedals
35th Gauge Bezel
Maximum MotorSports 4-Point Bolt in Roll Cage powder coated satin black
FRPP Boost Gauge
AeroForce Interceptor Gauge with added Oil Pressure and Temperature
Dual Pillar Pod
Schroth 6 Point Profi 2 Harnesses
Exterior:
2003 Cobra Front Bumper with Fog Lights
2003 Cobra Side Scoops
2003 Cobra Rocker Panels
2003 Cobra Rear Bumper Cover
2003 Cobra Side Mirrors
2000 Cobra R Functional Front Bumper
2000 Cobra R Wing paint Gloss Black
New Black Bezel Headlights
APR Carbon Fiber Functional Adjustable Rear Wing
Tiger Racing Functional Heat Extractor Lift off Race Hood
Steeda Cowl Hood
Sent him an email Feb 06 and got a response back April 9th.
I want this stuff if he ever gets back to me.
ranger2339, i have sent countless quotes to people over these passt couple months and no one has ponied up the cash to do a deal.
If I sent you an email back, then why didnt you respond and send funds?
Please send me emails people, it is too cumbersome to go through the forums.
Thanks.
