1 - 1 of 1 Posts
For sale. Completely parting out a 1997 cobra. Ask for anything not listed.
Motor:
B heads 69k miles. Valve covers, Cams tensioners and chains. $750
Timing Cover $120
MSD Coil packs for 96-98 with 8.5mm spark plug wires $200
TedSkid block, Kellog Crank, stock pistons and rods, Cross Hatching still on walls. $1400
IMRC Delete Plates, Home made $140
Starter $30
Coolent Cross over tube, Just put on minty. $50
2 Alternators, work great $30 ea
Stock rad and fan $40
96-98 cobra intake $450
Supercharger:
Vortech V2 Supercharger with aftercooler. Mint, almost zero miles on this. Car never got finished.. still had stock injectors lol so never tuned for boost. Paid 5900. Will sacrifice at $3800.
Transmission:
Spec stage 3 clutch, mint 10 spline $200
Cobra Flywheel stock replacement with boths $20
T45, 69k Shifted great, fluid perfect $450
B&M ripper shifter, T5 t45 $100
TR 3650, Slight grind into second, bellhousing, stock clutch driveshaft. $500
Suspension:
Cobra Front sway bar $40
Strut Tower Brace $40
Steeda Clutch Quadrent 79-04 $20
Eibach Pro Kit Springs front and rear Kit $120
UPR non adjustable rear control arms $100
Steering shaft $30
Megabite Sr control arms with relocation brackets and new heims $200
Exhaust:
Flowmaster cat back with tailpipes $250
Mac off road H-pipe with Mil eliminators for long tubes $120
Mac Chrome long tubes 96-04 cobra $400
Interior:
Tan Leather Perfect front and rear sn95 Seats $450
Brakes:
Hydroboost And master and Rack $200
Wiring:
Both Engine Harnesses $make offer
ECU out of 97 cobra
Cluster out of 97 cobra
Fuel System:
Full Aeromotive Eliminator Kit. Eliminator pump, 100 micron and 10 micron filter. -10 out of tank to pump -8 to front of car, Y block, 96-98 Aero rails, -8 out of rails to Aero regulator to -6 return with aero sumped tank. $1250 with rails $1100 with out rails.
Exterior
97 cobra hood $120
Call or text for pictures 8606708089. Obviously I can't post all these photos but I have them on my phone. Paypal is fine or pick up in Windsor locks ct 06096.
1 - 1 of 1 Posts
