1 - 15 of 15 Posts
everything is available except for suspension, rear, distributer, shifter and some other odds and ends. car runs and drives, so if your interested in the motor or trans you can hear and drive. i dont know what model the trans is but its a tremec 5 speed.
just the short block maybe for sale i dont know yet until i look inside.
trans maybe sold depending on the model
87-93 cobra R hood with svo scoop---$200
ford motorsport 160 speedo---$80/speedo only $100/whole gauge cluster
2-15x7 weld draglites---$150
1-15x3-1/2 weld drag lite---$50 if straight, i havent checked yet
1-5/8 unequal bbk chrome shorties---$100
unknown name h pipe for shorties---$40
flow masters with flow tubes and no tails---$50 SALE PENDING
i have all the interior and exterior parts. car is a sunroof car
i have 2 maf for 94-95 one used in like new condition and one brand new both with electronics
94-95 upper and lower intake with throttle body
will have pictures soon
If the rear wheels are not bent and in useable condition then i am interested.
You only have 1 front wheel?
Where in MD are you?
I am up I83 above york PA.
I may get other stuff if I come and see the car.
Whats the back spacing?
Do you only have 1 front wheel?
Are the headers/exhaust still for sale? Cluster?
Where in MD are you? I'm in Baltimore and can pick it up.
Are you parting out the interior too? If so what color is it?
Discussion Starter #12
im going to put the tilt wheel out of this car into mine but ill have an air bag column if your interested in that
Discussion Starter #14
you will need the air bag column if plan on using a quick disconnect steering wheel. cant use a quick disconnect on a tilt column. $75 plus shipping for the air bag column.
1 - 15 of 15 Posts
