Just wanting opinions on current my build. Et wise{ not very important as its more street than strip## ,hp/ boost spool wise and etc. See anything you feel i should do poat up.. and yes i know the stock block strength. Thanks
94 roller 351 with 410 forged eagle neutral bal. Kit 9.5 to 1 comp.
Custom ground turbo cam 580/580 116 lobe sep
Super Vic intake
750 blow thru e85
Turbo kit 1" 5/8 bbks 2.5 crossover and 60mm single gate.
94mm thumper with 1.0ar
Intercooler is here but haven't decided on using it..
C4 trans with brake
3800 stall
3.31 gears
30" tire
3600lb truck..
I have almost the same setup except an s480. Should easily be in the 5s and be a blast to drive on the street. What heads?
