1 - 8 of 8 Posts
This is a cam adperformance has spec'd out for me and I am looking for opinion on it as I don't know what I am looking at lol. Here it is:
GRIND #: FW 3015F /3035F HR112.0
SPC INST 1:
SPC INST 2:
J. DIAM: STD INT EXH
VALVE ADJUSTMENT HYD HYD
GROSS VALVE LIFT .574 .566
DURATION @ .006
TAPPET LIFT 274 276
VALVE TIMING OPEN CLOSE
@ .050 INT 0 44
EXH 44 0
SPECS FOR CAM INST. @ 112.0 CENTERLINE
INT EXH
DURATION @ .050 224.00 224.00
LOBE LIFT .359 .354
LOBE SEPARATION 112.0 FIRING ORDER STD
ROCKER ARM RATIO 1.60 1.60
Now some info on the car: 93 mustang vert, dart 347 big bore, tfs r heads, r box intake
t56 magnum 6 speed 2.66 first gear, 3.55 rear
custom billet ceramic BB 7668 turbo from customracingturbo.com
This is going to be mainly street driven on pump gas/meth injection. Looking to run maybe 14 psi and make around 700hp but probly won't run that all the time.
Just looking for some thoughts on this cam before I have it made.
kinda like a F cam. seems a little small for your motor, i had a custom one made and its alot bigger then yours almost the same specs.
Just got my new "turbo" cam from Ed. Granted mine is for a 408 but it's got about .030 more lift and 10* more duration. It's on a 115 lobe seperation. We have about the same goals but I'm using a BW S475 turbo from Reed at workturbochargers and only about 6-8lbs on pump gas (hopefully)
You need more duration imo. That cam will peak early in the rpm range.I would go with something in the 230s on a 114+.
Ed seems to like the big lsa. He ground mine 116.
Mine is 363" with twin gt35's from Reed. I told him mine was gonna be 50-50 street strip and I ended up solid roller 600 lift, 236-242 duration, 116 lsa, installed at 112 lca.
1 - 8 of 8 Posts
