1 - 20 of 20 Posts
Open Track Car Complete!!
1991 Fox
Full MM suspension with coil-overs. 400lbs Front 300lbs rear with MM spec Bilstein shocks. 275-40-17 all four corners.
Dart block 383 stroker built in my living room. (My wife is very understanding...) 486RWHP 430RWTQ
Brembo Cobra R brakes with Coleman 2-piece rotors. Cobra rears. Carbotech pads.
First time on track with everything is May 21st at Putnam-Park with 10/10ths Motorsports.
Discussion Starter #2
Sorry about the title, I'm not sure what happened with that. Apparently I cant change it.
Anyway, here's the Dyno Sheet. Naturally Aspirated Small Block Ford
Looks Great Neighbor
Great to have another Central Ohio Fox body RR in the mix.
Brian at Dynotune is great to work with. Helped me with my 331 tuning for a balanced power curve and partial and roll on throttle mapping.
Looking forward to seeing you at the track.
BTW, NASA and AutoInterests in our area also offer well run, instructive programs with great track time experiences.
Nice, flat torque curve and it seems to pull hard to 7,000 rpm. What induction? 9.2 deck block? What is the combination? LS or Ford?
Thanks! I've been out with NASA a few times to Mid-Ohio. Have you ever been out with 10/10ths Motorsports? This will be my first event with them.
383 I believe makes it a Cheby.
This is NO Chevy motor!! Its ALL Windsor! Its a 351 based Dart block! 3.75 inch stroke with Cleveland mains. AFR 225 heads and a Edelrock Super Victor intake converted to use EFI.
It's not quite the traditional 351 stroker displacement. It's an all forged, internal balance Eagle kit. For what I wanted to do with this car, I felt the better rod ratio and lower piston speeds of this kit was worth giving up the 25 cubic inches of a traditional 408 setup.
Good to know. I was going to consider you a traitor.
sick build! Let me know what you think of the 400/300 springs, i just removed mine for 500/400 i always thought the 4/3 were to soft, now i need to bump up to MM/Bilstein MM3 race dampers (let me know if you want another set of the MM sport dampers.
Discussion Starter #15
What block did you use? Is it the 9.2 deck? Do you think that new Boss style hood would have cleared your TB Elbow?
Dart SHP block, 9.5 deck Windsor. I have absolutely no idea about the boss hood.....
Cool. I have a friend that has one of those hoods and the amount of clearance with them is deceiving. You have more than you think you would, that is the only reason I asked. He had a lot of clearance with his setup.
Very nice indeed. Cam specs? What engine management system are you using?
Discussion Starter #18
The cam is a custom spec road race solid roller from Jay Allen. Stock computer with just a dyno tune chip in it.
Discussion Starter #20
No class. It's just an open track/ HPDE car that I can drive on the street when I want to.
1 - 20 of 20 Posts
