1 - 20 of 28 Posts
Hello there went to the track the other day and my current setup only managed to scrap a 13.8 down the 1/4 but I know the car should be considerably faster, but why is the car not running to its fuel potenal? Is this just a crap combo? Any input would be very much appreciated
Current setup: GT40 intake, CAI, 70mm TB, TFS 170 heads (61cc chamber), 1.6 TFS RR (3/8 a turn of preload on lifters) TFS track max (stage 1) Cam, HD clutch, aluminum DS, 3.73 gears, 255 LPH fuel pump
The car managed a 1.8 60ft on street tires I can’t remeber exact numbers but i think it was around 100mph
What kid of suspension work has been done to the car? Any idea on weight? Elevation? If you're only trapping 100mph it sounds like something is off.
100 mph seems about right for a 13.8 pass. And a 1.8x 60' time is very respectable for a street tires, or slipping the clutch with stickies.
I would think the car is capable of mid-to-low 13s with the mods, realistically, on street tires. I'm guessing you should be making around 270 hp at the flywheel. It seems to me like you are down on power.
When my 87 was bone stock, w/ 5 spd and 3.08's, it ran 13.95 @97 on the stock Gatorbacks, in good air. 60' was 2.0x.
Lots of things to look for. Cam in right? Ignition timing good?
I 100% agree the mph sounds right for the et. Especially with street tires (with the right tire/suspension it could be a low-mid 13)
Not knowing anything else about his car/setup/location it's a wild guess but I would think his engine combo should be trapping slightly faster than 100mph in your average fox body assuming it's healthy and tuned properly.
I was thinking the same thing about the ignition timing. I would double check that. I had a friend who had a H/C/I 302. It ran [email protected] Of course we thought the same thing. That it was down on power. We went back and checked the timing. Initial timing was 0. Put it at 14 and it ran [email protected] It definitely sounds like your are missing some power.
Discussion Starter #12
Appreciate the input guys! But the suspension is very simple stock up front, and white line upper and lower control arms on the rear with strange 10 way shocks. The track I go to is a little over 1000 feet that day it ran a 13.8 was about 90+ out with the track temps around 110 so heat was a big problem at the time to my knowledge the cam was installed properly will be double checking that tho since a rocker keeps managing to come loose over time? ? but timing could okay a factor I just slapped the new harmonic balencer on and called it a day didn’t really think about the way it’s oriented with the timing marks on the balencer! I’ll double check timing and see but it should be around 11-12 right now just timing it off idle
Remove the spout connector before you check the timing.
Something is off for sure.
Back in the day I had a 1990 GT convertible with T5. It was a totally stock, full weight car to which I added 1.72 rockers, a B303, 1 5/8" shorty headers and a full 2.5" cat-less exhaust. Suspension was stock except a pinion snubber. Rolling stock was Draglites in 4" and 8" widths. 275/50R15 drag radials. I never believed in tricks to run numbers so I ran it as it rolled the streets. Spare in the trunk, no icing the intake, no short belt, etc...
I ran many 13.8's and 13.9's at 98-99 mph. So very many. One day I ran a 13.78 at 100 mph. Fastest and quickest it ever went. Still never did the 60' in less than 2.xx something.
That car was heavy, all things considered. I would think you could/should be a half second quicker with a couple more mph to boot.
Discussion Starter #15
Exactly why I’m confused as to why I ran the number I did it’s very confusing I’ll be double checking the timing marks on the balencer and timing the car to see but still no idea
what RPM and how are you shifting?
Seat time will help out once you make sure your power issues are checked and sorted. I was able to shave nearly a second off my best ET on a new set up with a full day at an empty track test and tune. made 20+ passes and went over each time slip and made notes on launch RPM, shift points and anything I may have changed from one pass to the next. Once I got 3 passes with times that were very close I would make another change and make more notes.
Car has the capability of running 12s with that motor. Sounds like you have multiple issues. I would start by buying a pair of 26x8 drag slicks. No need to waste money on suspension parts with no more motor than what you have. Slicks are the great equalizer. Once you know the car can't spin the tires, then you can start looking into other problems.
I had a 92 with 373's, big and littles, an off road H-pipe, cold air kit, and some weight loss. It ran 12.9's and never had a valve cover off. You need tires more than anything I think. I would also play around with the shift points to find the best spot. My stock engine got shifted at 5000. Any more or less made a big et difference.
One of the things that I noticed on mine when I had it was that the timing was WAY too far advanced. The engine "liked" 32 degrees total timing; however the A9L's stock timing table, with 10 deg base, was running closer to 40 deg at full throttle. In my experience, once you start getting over about 34 degrees with aftermarket heads, the ET and MPH fall off-on mine, about .3 slower at 38 degrees. At the track, I'd pull the base timing back to zero to 2 BTDC, and it'd pick up a bunch. I don't know of the TW 170's are as sensitive as the AFR165's were, but it's worth considering. It may be advantageous to have it tuned on a dyno if the budget permits.
100mph is very low for those heads, cam and intake, so i'm gonna guess that it hasn't been on the dyno or at the very least you don't have a wideband?
what maf?
what injectors?
what intake tube?
what tb?
what's the full exhaust made up of?
1 - 20 of 28 Posts
