Does anyone have a diagram or can explain the way vacuum lines are run for the boost controller on the single turbo Foxbody kit. Most diagrams online show 2 ports on the waste gate or running from the turbo housing.
Leave the top vent open and just use the side for your vac line. The boost controller goes between the wastegate and the source. I have mine coming from the TB nipple that use to be used for the pvc system instead of off the turbo.
I run the BOV off the vac tee on the fire wall.
