1 - 15 of 15 Posts
I have an on3 and I've been using an oil relocation kit. I'm constantly worried about the lines feeding it getting to hot since they are so close to the headers.... In fact, I had a line crack before- it was a slow leak and oil was hitting the header making lots of smoke. A big leak could be catastrophic. At the time I replaced the bad line and worked to get it routed better away from the headers. It seemed to work just fine. But I was always nervous about it.
Now, my new frpp boss block is going in - with the on3 turbo. Reuse the relocation kit? Use it with braided ss lines? Use the short oil filter?
A complete loss of oil would be double catastrophic now......
When running the short filter do you change oil more often? Change filter halfway through oil changes? Or let it go and treat as stock oil filter? If it matters I run mobil 1 and go 5k between changes.....
THANKS for advice!
If not the 90 adapter use the short filter. Not only could the loss of oil be catastrophic, if you lose it and it ends up under your rear tires it could be far worse. In my experience those relocation kits always leak from one place or another.
I ordered the 90 adapter last week for my build
Good point. The 90 adapter is on it's way. You decide if I'm cheap or broke or both, but it's a few dollars cheaper plus no sales tax (in tx) from Summit.
Thanks!
Plus you dont have rubber hoses by the headers, thankfully I got advice on this one to
Not fromwhat I've read, as that filter is recomended by Ford for a bunch of vehicles
sounds like you guys are talking 302 base motor and not the 4.6
1 - 15 of 15 Posts
