threw a rod in my stock short block 302. was wonder if the 302 turbo kit will bolt up to a 351 or am i just stuck on having a 302 because my performer rpm heads and intake will bolt up to 351.
351 kit is different. the engine is taller and wider.
302 heads may not bolt onto your 351, unless they have 1/2 bolt holes in them
the lower 302 intake will not work on a 351 (you can buy the lower to use on a 351 IIRC
