Anybody know where the air charge temp sensor moves to when going with the on3 kit? I think that is what you call it. It is the sensor between the air meter and the throttle body on the stock setup. I know they are in the lower intake in the #5 runner on a fox. I have tried to call them several times to ask with no luck.
Thanks, Billy
I'd put it in piping between the intercooler and the throttle body. You'll get more accurate readings there anyway. If you put it in the intake the sensor gets heat soaked and your ait reads the same as your engine temp regardless of your actual ait's which will cause your computer to pull timing reducing your power.
