1 - 20 of 22 Posts
Hi just trying 2 get some info from those using on3 performance turbo kits on there 5.0 mustang. I am looking at getting 1 of these kits with there fuel pump,injectors oil relocation kits& there y pipe. What beside this kit will I need 2 get? My mustang has a stock bottom end ,has a f cam & gt40p heads. Also what kind of power am I looking at getting from this kit
Don't buy the kit! It is pure junk(ask me how I know) piece it together, it won't be much of a price dif and you will save your self a lot of headaches!! If you are looking for a one stop shopping call Chris at poweraddersolutions he is great to deal with!! Also if you haven't ordered the turbo kit yet DO NOT ORDER IT FROM ON3!! get it from jegs or poweraddersolutions that way if you have a problem you can deal with them and not On3because On3 is nearly impossible to get ahold of!(again ask me how I know)
Agree 100% my kit came from Jegs but everything else came from poweraddersolutions
I will say that my ON3 kit is complete garbage and I wish I never would have bought it.
Well I know I don't have a 5.0 kit. But for the money I can't complain at all about my forward facing 2 valve kit. It fit just as good as my friends hellion kit and make about the same power.
Sent from my DROID BIONIC using Tapatalk 2
I must be really lucky then,my kit fit well performs awesome makes great power...I drive my car daily too...Guess it the luck of the draw..Also i had a shop install mine...Maybe just maybe thats why i have no problems...They installed a few on3 kits the shop likes them,.they also installed other kits to them they like the On3 kit..And so do I....
Same here. No issues with mine. It's been up and running for about a year now. Almost done putting another kit on my buddies Fox too. And his fit just fine as well.
With the way the dp is on the 5.0 kit it looks like it would be a pita to change the plugs on that side. But I have never seen one in person. I love my 2valve kit.
I was just thinking about that recently....I'm guessing I'll have to remove the downpipe to change the passenger side bank of plugs.
I had the fox body on3 kit with the mp76 n upgraded intercooler.... Boss block 348.. fit wit no problems car made 800 hp to the wheels... 18 psi 93/110 octane mix..I also ordered thru on3 performance this was 2 years ago though...
I dont think the kit fits bad(actually went on easy). But the first time i went to start it one of the injectors stayed open and filled the cylinder and hydrolocked the motor bending the connecting rod! Jegs sent me another set of injectors and these ones seem to be working fine. I tryed calling On3 atleast 50 times and no answer(also his voice mail was always full).As for changing passanger plugs just unhook the dp and let it go down change plugs and pull dp back up!
mine works greatno problems. i already had fuel system components. so i can't speak on the quality of those.
Lol!!! I ordered my on3 kit from jegs sept 6, got box 1 & 2 sept 10 but box 3 wasn't there so I called jegs on that Monday the 10th and they said it was going to be drop shiped from on3 and I should have it by Thursday. Well never got box 3 so I called jegs back and they say they can't get on3 on the phone or email!!!! So i thought by ordering from jegs I could avoid the BS but looks like that's not going to happen. So here I am waiting on box 3 witch contains the down pipe and all the cold side pipes?!? Sucks!!!!!
That sucks but atleast you can get ahold of jegs to get your money back if u half to! If jegs can't get ahold of on3 do u think u will be able too!!!
I ordered my on3 351 kit in late November 2011. Everything showed up month later. All the parts.
Installing now all seems well.
Travis
Ordered my kit through Jegs and was able to get through to someone every time. It took a couple months to get the last of the three boxes shipped, probably because it had the hotside in it, which takes the most time to make. Mocked it up and everything fit well. I still plan to get the upgraded gaskets and V-bands for <$100 though just to be on the safe side.
I know one buddy of mine has the On3 kit installed on a notchback, stock longblock and suspension, explorer intake, 70mm tb, c4 w/ stall, trans brake, no exhaust, BTM, 3.27 gears running 11.18 @ 122 on the 9 lb spring
Well I got to give props to jegs on this one, they have called me 3 or four times sense I called them the first time asking about the 3rd box! All they tell me is their waiting to hear back from on3! but hands down to them for staying on top of it. Thats customer support right there!!!
And for a question for the people that have the most recent on3 kits, what kind of wg and bov is in the kit? Sure looks like Tial wg and bov?!?
1 - 20 of 22 Posts
