1 - 14 of 14 Posts
Hey guys I have 92 mustang car ran great no issues at all. Bought an on3 kit and all supporting mods also installed trick flow heads and the car hesitates at times my mechanic changed every sensorspent countless hours trying to figure out what is wrong I have heard on3 injectors r no good this is the last ditch effort anybody else have these issues?
hesitation is sucha broad statement..
could be numerous things
such as:
- injectors
- MAF
- spark plugs
- wastegate
- spark issues
and a ton of others...
start with the injectors and fuel...and then spark plugs...
Im going through the same thing!when i started it for the first time i was unable to
set the fp,it wont move with vacuum on or off no matter how much i turn the screw
in or out so now im going to switch out the injectors and see what happens. I already
eliminated the pump so i think it has to be the injector or fp regulator but the regulator
never gave me a problem before and i also have on3 injectors which ive read are junk!
By the injectors being bad do you mean like broken or not big enought?
I only stock Ford Racing and Siemens Deka injectors, there are better injectors out there such as ID possibly but I highly doubt thats your issue. Is the car tuned or at least a base file in it?
yeah, I'm surely guessing he slapped the turbo on and went beating on it
This thread is 2 years old...
ks
It is but relievent. On3 I have a set of your injectors a bit older. Before I use them I need to know were there ever injectors you sold that we're not legit? If so, can I look at them and tell?
What is stamped on the housings?
I will take a look madspeed. They are with the kit and car at another garage.
In the mean time can I get a response in general? It's been 6 days.
Yes, GET A TUNE
Was that for me? I don't need a tune right now. I need chad to respond to my question.
I'll have the stamping from them today to reference.
1 - 14 of 14 Posts
