1 - 9 of 9 Posts
Has anyone tried the on3 fuel system kit in there foxbody ?
What's the deal with the filler neck mod, what did you do to make it work etc , considering purchasing the kit
Right from the website:
The tank will bolt in with the stock straps but will require you to modify a filler neck from the 96-04 cars. Its pretty simple to do and we have photos we can supply if you buy a fuel system from us. This is a stealth system and will look like a stock tank but support 1000+ RWHP. On our shop 1990 Foxbody coupe, the filler was basically cut into 3 pieces, shortened the distances and welded back up.
Yep read that , was looking for other opinions from people who used the kit , but thanks
They don't answer the phone or email , so I'll probably be going with another option ...
I'm going to use the ON3 kit. I'm just using the tank and their hat. I'll run my own lines and such. I already have rails and will just need a good regulator. They answer the phone every time I call.
So the Glenn's doesn't come with lines?
1 - 9 of 9 Posts
