1 - 20 of 37 Posts
Please follow this format:
Car
Year
Trans
Engine/combo
Turbo
PSI
RWHP
RWTQ
Type of dyno
Post your chart if you have it.
Post your time slips or ET/speed.
Discussion Starter #2 (Edited)
I'll get this started:
Car Mustang LX Hatch
Year 1992
Trans T56
Engine/combo 331 Stock Block/TFS 190 heads/FCam/Victor EFI/42lb injectors
Turbo MP 70
PSI 4.6
RWHP 497
RWTQ 441
Type of Dyno (will find out) Tuned by PSR
Dyno chart:
Time/ET Ran (1) 12.70 at 117 and split the block (hit the rev limiter in 4th w my 3.73 gears at the 1000 ft mark)
Any idea what more (street friendly) intake would be like besides that victor. Like a cobra or track heat? I wonder if you'd see 8-10 lbs closer to 3k? Any ideas out there gents?
I'm sure the mid range torque would be much higher and the hp would nose over sooner. Mine will spool to whatever I set the boost controller to by 3k. For me too much torque is already a problem. I am changing from 3.73 gears to 3.27's and swapping the T56 for a built c4.
Car Mustang Gt
Year 2002
Trans stock TR3650
Engine/combo 5.0l storoker with turbo cams stock heads
Turbo Master Power T70 with .96 housing
PSI 20 psi
RWHP 687rwhp
RWTQ 677 torque
Type of dyno Dynojet
Street friendly? Tell me your not a member of the crew that beleives bigger intakes and heads on a 302 make it hard to drive on the street lulzzzz.
Exploder Short
TFS Heads
E-cam
JAP 70
10 PSI
C4 3K converter
Now 3.27's DR's
HP TBA
TQ....Boatloads!
No, Im a member of corral asking a question. This guy^? And if u read alot of dyno graphs on intake comparisons you would know that the power does come on in diff RPM ranges. Also I used street as a term to describe a type of intake. Never implied it was hard to drive on the street.
Fmyth- I didn't even notice u were running the victor also, I was looking at the other combo. Seems your curves are some what similar.
It's a fair question. If you are talking about an NA car or a Centri SC car then yes you may like running a longer runner intake like a Cobra or an Exploder for a street car. If you have a turbo it does'nt make a whole lot of difference. Even at 4.6 psi the torque is sufficient to overwhelm the drag radials in first, second or third gear by 3,500 rpms.
I have or have had the Explorer, the Cobra, Performer, Systemax and the Victor EFI on my cars and cant tell much of a difference on the street with the turbo.
You can make enough power with any EFI intake and a turbo to break your block.
Car Coupe
Year 1990
Trans AOD
Engine/combo Stock cam/block AFR 165's, 70mm TB, PP intake
Turbo 70mm stock On3
PSI 8
RWHP
RWTQ
Type of dyno 1/4 mile
Post your time slips or ET/speed. 11.44 @ 122
Car: Cobra
Year: 1994
Trans: stock t5
Engine/combo: Stock except for F cam
Turbo: on3 70mm
PSI: 9lbs
RWHP: 393
RWTQ: 452
Type of dyno: Mustang Dyno
93 Lx
Stock bottom end ported E7 heads Fcam gt40 intake
Base On3 kit on 12psi
477rwhp 502tq through a t5
11.22 1.85 60ft with a c4 and a 4000 stall converter faster times to come
Car: mustang hatcback
Year:1992
Trans: Art Carr AOD (3500) stall
Engine/combo: stock block, stock cam, TF170 Heads, TFR intake, 70mm TB.
Turbo: ON3
PSI: 6 &10
RWHP:363 & 468
RWTQ:437 & 525
Type of dyno: dyno jet
[email protected] on 9psi. Off the trans brake.
Discussion Starter #16
Car coupe
Year 87
Trans c4
Engine/combo 347, TF190, F cam, Vic EFI, 70mm TB 42lb Ing
Turbo 70mm MP
PSI 4.5
RWHP
RWTQ
Type of dyno
Post your time slips or ET/speed. Heading the the track for the 1st time Sat. Will update.
Car coupe
Year 04
Trans stock 3650
Engine/combo mmr 4.75 900/ stock heads w/bronze guides,springs
Turbo on3 70
PSI 10psi----18psi
RWHP 474-----??
RWTQ 512------??
Post your time slips or ET/speed. (10psi) 11.9 @ 119 1.89 60ft
new dyno tune for 18lbs coming soon.
1 - 20 of 37 Posts
