1 - 10 of 10 Posts
well last night looks like a tbolt clamp broke well that was all i could find at the end of a test run my 90 pipe with blow off valve blew off bounce off the ground smacked a hole in my gas tank.anyone know if on3 sell parts single yet or another company that would have the same style setup to replace it all i found was a broken tbolt clamp and one hose the valve must have flew off in to a farmers field not about to knock on doors to go find it lol.
it s a 3' 90 bend with blow off in it gona try and call on3 in the morning but i may build a new cold pipe and mount it to the radiator support so if i blow a hose i dont lose my blow off valve again and may up grade to a tail since my 383 is almost ready to go in
making me want to hurry up and get it together lol but still working on my take offs and finding traction with my stock block 5.0. since i will have to get a new tank now will upgrade fuel system i think now
Wow...that sucks...Im sorry to hear that...Makes me wonder whats going to fall off mine...i better check all clamps to make sure everything is snug...
ive seen this happen on kits where the clamp was over tightened, stretching the bolt to it max!
call on3, i know they can sell you a new blow off valve
well tbolts had been on for 2years with no isseus at 6lbs turned up to 10lbs for about 6months now.on3 said 2weeks or more on a piece of pipe and another blow off was in stock so just gona fab my own up and solid mount to the radiator support so if it happens again i dont lose my blow off valve
As long as its bead rolled and coupler is attached right, you do not need any sort of a stay or bracket. There are plenty of guys 15-20psi without needing those sort of things. Just make sure its rolled at the ends. Hair spray also on the couplers works magic if your worried about them popping off. I have had setups before I didnt get to roll and used that and was hard to even get them back off
The way I secured mine was to put a ziptie on the hose as a clamp. And then tied the hose up with another ziptie. So if mine were to come off, it would just dangle beneath car by the hose.
update well after going over this i purchased my kit used and owner before cut the u bend going to the intercooler wich cause there to be no lip for the hose to clamp to
why i was only missing a 90bend insted of the 180 u bend.
so with some help from chris at pas and chad at on3 got i figured out and chad is hooking me up with a blow off valve and adapter quik shiped ups so i can get back runing.
thanks chris at pas and chad at on3 for helping me figure my issue and fixing it
1 - 10 of 10 Posts
