trying to figure out my oil drain set up for on3 5.0 foxbody kit i have the on3 76mm turbo with the oil feed level i dont see how the drain can work it real close to the ex housing once the 3/4 drain hose is on there may touch or even be few mms away from it only thing i can think of is clock the center section at the 10 o clock postion but afarid of turbo damage my last turbo was clocked this way on my treadstone ebay kit and never had a turbo problem at 8lbs any ideas would be great
I have the sn95 kit and I dont have any issue with it being too close. However, I would not clock the turbo. I would leave it straight up and down to prevent any damage to your seals. Can you post up a pic of what you are talking about?
update so far i got plenty of room to run a 1/2inch setup without any issues
also to go with the 3/4inc setup i used a 2inch brass pipe wich gave me plenty of room from the turbine housing for the house to be safe but will have to notch the frame rail a little bit so the hose wont rub on it
