1 - 11 of 11 Posts
Wondering if anyone has pushed this turbo into the single digits. Also wondering how spool up is with a .68 ar? Thinking of putting one on my 260 ci v6 engine. Currently has an s366 on it now.
I'm pretty sure on3's 70's have been in the 9's on several different combos. I would think your S366 performs very close to a on3 70. Is a precision 67 a option for you?
The 70mm was thrown in on a trade and couldn't pass it up. I've had the s366 up to 17psi and run 105 mph in the 8th.
1995 GTS, 2014 GT/CS
My stock shortblock 302 went numerous 9.90's with a 70mm. That was with mediocre sixty foot times (1.45 being the best).
Yeah, but that's with a REAL motor, not a 2 cylinder delete model. I'm not saying it's not possible, but probably outside the compressor range for a 70mm On3 turbo on a V6.
Real motor? You line your piece of #### up next to mine and I guarantee I'll drag the bumper off that bitch! And the turbo will be more efficient on a smaller motor dumbass.
  • Like
Reactions: Sonicboom347
I'm glad you'll enjoyed it! I didn't start this thread for a debate on v6 vs v8 and I'll admit I was trolling a little bit lol.
On a serious note, where does this 68 ar housing run out of steam? A little about my motor is 260 ci and makes 280-300hp na. I had a .63 ar t3 on it running through a 62 cea turbine and the load would fall off a cliff above 5400rpm. Hoping the 68 ar will allow the motor to rev to at least 6000 rpm. Funny but there use to be a bunch of info on this unit on this site but cant seem to find it. Remember there was a max hp thread and fastest time thread as well.
1 - 11 of 11 Posts
