1 - 13 of 13 Posts
Just the one pipe like you see in the photo? I only run those in 3" but it would be relatively easy to fab one up if you just needed that one section
I would like both pipes on that side in 3.5" If you could let me know how much it would be with the silicone couplers, and with/without the maf flange i'd appreciate it!!
I just had a few 3.5 bends I could do that first pipe out of really easily. It really doesnt all need to be 3.5", 3" is more than enough but putting the maf into a 3.5" tube would give you more range
I know this is an old thread, but I have a question about the MAF you used. I have the same one on my fox (NA) and would like to reuse it with the turbo as you did. Did you have to do anything to modify the pipes for it to be able to fit there? Did you have to buy any new couplers or anything? As much info as you could offer about this would be awesome!
1 - 13 of 13 Posts
