1 - 8 of 8 Posts
Im gonna be ordering my kit next week and curious as to what other 351w guys are running for fuel and what not. I currently have plenty of fuel for 700+ RWHP but wanting to sell all that if i can and run a more practical setup.
Im hoping 42s or 60s for injectors and may try out that new 340 intank pump and stock lines. Im just gonna run the 70mm for now on a H/C/I low compression 358W
I am running the 70mm 351w kit. Just got 300 test miles on it tonight. Get the 60lb injectors for sure. I am running a stealth 340 lph with a 97' tank pickup with -8 AN bungs welded on, Summit 1/2" twist tite fuel lines and 8 AN fittings, mallory 1/2" bore rails. Running 12 PSI with no problems.
i bet that 70mm comes on instantly with that 351.. does it have the .96ar??
On3 says .96 but the turbo says 1.0 A/R. Yeah boost hits under 3K easy, Scary! Can't wait to dyno this thing and get it to the track!
hell yea, id like to see a video when its done.. im doing a 351 now with a T76 with .96ar and wonderd how it would be..im also going to buy a 1.15 ar and test it too..
im sure that 70mm def comes on quick behind the Weesor...curious to see how mine will turn out
interesting,. im debating whether to do the same on my 351W,.
1 - 8 of 8 Posts
