1 - 11 of 11 Posts
which felpro gasket for GT-40 irons?
10111- has a steel wire ring
10112- has a copper wire ring
which one is best for iron heads??
thanks,
adam
Moderator & USAF (Retired)
Neither, of the two listed the 10111. But I would run the conventional FORD replacement gasket (felpro standard graphite head gaasket) Less likly to have any problems, better seal, less coast, and no machining required.
oh ok, thanks guys.
i just heard that the wire ring helps aid sealing. so its not worth it???
thanks,
adam
ok, so i just went and picked up the head gaskets that billy recomended.
are the head gaskets only supposed to have the rear coolant ports open? why is this??
and for the middle coolant passages, they only have small holes to flow through. can or should i open these up a bit?
thanks,
adam
The open coolant holes go towards the rear. Don't open up any of the coolant holes, I don't want to get technical right now, but, they are that size for a reason. I have the motorsport graphite gaskets on my car, and it runs nice and cool. Also using N2O with no sealing problems!!!
ok thanks,
i just didnt know if they were supposed to be closed like that. i didnt want my temp rising with this head change.
thanks,
adam
Holes in the back:
Think of where water comes into the block, the front at the pump. Think of where water leaves the heads, also the front, out of the intake manifold. If there were holes in the front, the water would bypass the block and heads and go straight from the pump to the radiator. The blocked off front holes forces the water to go front to back of the block, into the heads, back to front of the heads, and finally out of the intake. I think the little holes you mentioned are just to help get air out.
Billy
thanks Billy, that cleared it up...
adam
1 - 11 of 11 Posts
