1 - 9 of 9 Posts
Wanting to know what kind and where i should purchase the supply and return oil lines for my turbo stang.
Supply needs to have female ends and the return needs to have a slip on one side and i would prefer and female on other end. Because im going to weld a pipe bushing to my oil pan after drilling hole and the nipple the return to the pipe bushing on oil pan.
Any better ideas of doing it or what. Input appreciated.
Discussion Starter #2
I need them to be longer than the ones that came with the boost brothers kit. I have the supply for the kit and its too too short.
welding the steel an fitting to side not bad idea.
But probalem is i need maybe 4 or 5 foot long lines and one as to be female on one side and slip on other.
And the an lines wow exspensive.
Supply line is a pretty basic -4an I believe. Any speed shop or jegs/ summit will have what you need.
Return is 3/4" hose, any rubber oil hose or -12AN will work. Fittings are your preference. 3/4" nipple on the turbo outlet and oil pan work, or you can use an fittings, both will be fine.
I hate to threadjack. But why does the return need to be so large?
I have some -6 that I was going to use. but now...... not sure. lol
1 - 9 of 9 Posts
