1 - 10 of 10 Posts
If u have a big enough drain u wont need a restrictor......at least thats what the general consensus is.
What weight oil do u use? 10w30 or 10w40?
What size is ur drain line? Hole in pan?
I believe i need one bc my exhaust smokes and then will clear up and then smoke. i have no restrictor as of right now just a 4an feed and 10an return. I run 5-30 oil
I was thinking to do the same thing and I called Precision and they said not to do it. IIRC they said that with journal bearing turbos there is no need.
1 - 10 of 10 Posts
