I took the end cap off my edelbrock performer rpm intake and noticed it had oil in the intake. Im not for sure but it looked like it was coming from fitting that goes to the pvc, I have a breather on each valve cover, so do i have to have the pvc hooked anyway?? I noticed it was smoking out the tailpipes, is that because of the oil in the intake?? any help is appreciated. thanks
just went thru the same deal.... block off your pcv valve ,run a catch can type breather system call it a day .
I did what you said i blocked off the pvc and put a breather in each one of my valve covers, now it is smoking from the breathers.. Is it suppose to smoke out of the breathers??? any help is appreciated.
331 stang can you post or send me a pic of your catch can type breather system. are if anyone else has pics can they post them. I got a breather in each vavle cover and have the pvc blocked off and it is smoking out of each filter. any help is appreciated
