Ok so i just got my twin turbo setup and im just wonder when the best way to run the oil drains out of the turbos would be. Should I have to separate ports on the pan or should i use like the y-block. I plan on running the mmr oil pan.
I would not Y the oil returns. Run a seperate return for each turbo. I welded -10AN bungs in each side of my oil pan in the position vortech recommends for their SC return, and then ran braided line for each turbo return.
I did that as well (10AN on each side of the pan). Another way would be to use hose barbs of the right size. That would be cheap and the drain is not under pressure.
Erich
